Guys ,
I Have recently bought a D16ZC swapped 95 Civic . It has a forged Bottom end . The car is currently running on a base map which is really rich . Like 11.5-11.7 AFR on idle . I`ll have it tuned in a week or so , i am just driving it normally under 2k RPM so that the boost would not come int .
Now there are two things which i am noticing
1-) The car has Ngk v-power 8 heat range plugs .
Now if i start the car after 1 to 2 days . It starts missing . Then i`ll have to take the plugs out and have them cleaned . It runs fine after that . The plugs have black carbon on them , with a sign of oil as well
Now if i use the normal OEM plugs , the car starts fine and there is no sign of oil etc on plugs as well after cold starts etc .
My mechanic is saying that you just need to get the car tuned with the 8 heat range plugs . I have been reading around and oil on plugs means worn out rings as well ?? can someone clarify this and give me a clear direction
2-) I am seeing some fumes coming out of the oil breather location , my mechanic is saying that this is normal for Forged Turbo cars . Please keep in mind that there is no oil coming out of the breather + the car is not loosing / dipping any oil or something .
He is also saying that your P2w clearence is a bit loose , but its not a major problem , you will just need a catch can .
I just bought the car and my scheduled tune is after a week or so . These two things are making me confused etc . I know that compression testing would tell me quite a log . But where i reside there are no mechanics having a compression tester or something . Also there are also not available in the markets as well
Can some gurus help me out here ? This is my 1st Turbo Honda . before that i had a starlet GT 4EFTE .
